Use the data in the following table to use the Interfaces tab.
  • In ExtremeCloud IQ Site Engine, configure your third-party virtualization platform, and the RADIUS server used for Endpoint Tracking authentication. For information about configuring ExtremeCloud IQ Site Engine, see the ExtremeCloud IQ Site Engine documentation at https://www.extremenetworks.com/support/documentation/.
  • On the switch, add and configure the RADIUS server as configured in ExtremeCloud IQ Site Engine.
Enable Endpoint Tracking on ports or MLT/SMLT interfaces.
  1. In the navigation pane, expand Configuration > Edit.
  2. Select Endpoint Tracking.
  3. Select the Interface tab.
  4. Select Insert.
  5. Select Port or Mlt, select the slot and port number or MLT ID, and select OK.
  6. Select InterfaceEnable.
  7. Select Insert.
  8. Select Apply.
What to do next
Next, configure Endpoint Tracking globally on the switch.
Interface Field Descriptions
Name Description
InterfaceIndex
Specifies the interface index of the selected port or MLT.
InterfaceEnable
Enables Endpoint Tracking on the selected port or MLT.
